Old 10-18-2013, 11:23 PM   #34 (permalink)
mr220v
The 1nzfe ecu runs the vvti based on rpm. I want to run it based on throttle position. With the setup I have, the vvti actually needs to operate more like displacement on demand than normal vvti. That's the object. Cruise at 750cc's, and move to 1.5L when I need to.
In the case of the spyder, the key would be the 1nz XA bellhousing accepting the spyder differential. I think it probably would. At that point, you would use your existing axles and transmission mounts.
