Old 10-20-2013, 02:12 AM   #210 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by josemapiro View Post
Thanks, had the cord exchanged. Now it works, but the values ​​are not correct, I have to set it to the car.
What is the best way to configure.
Well, you can use the calibration instructions. I think they go something like:
  • top off your tank
  • reset the tank trip in MPGuino
  • drive around, like you normally would
  • top off your tank again, noting how much fuel you used
  • note how much fuel MPGuino says you used in the tank trip
  • take your Microseconds/Liter (gallon) value, multiply it by the amount of fuel the MPGuino said you used, then divide it by the amount of fuel you actually used
You might could also tell us your car's year and make and model. It's possible that we might be able to find the fuel injector size, based on that information.
The Following User Says Thank You to t vago For This Useful Post:
josemapiro (10-20-2013)
