Old 10-22-2013, 08:01 AM   #154 (permalink)
Arragonis
The PRC.
It won't be here long enough to justify a tank fillup (I hope). Mid-40s is what it is returning according to the OBD but experience suggests VAG built in displays are hit and mess, usually optimistically.
Hermann update - inside the tailgate has corrosion so they are going to replace it completely instead of repair - which is good. The rear washer pump is leaking so they are going to replace that too but with a cost - which is not so good.
But it should be rot free which is the main aspect.
