Old 10-24-2013, 02:32 AM   #45 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by puddleglum View Post
It has 2 of the motors that mechman originally used in the Booger. I know it didn't work that well for that, but what about in a smaller, lighter car or a motorcycle?
I am wondering the same thing. I have been thinking that it would be interesting to try a two controller setup on my sepex motor in a motorcycle but with two twist grip pots - one for the left hand and one for the right, one controlling the field current and the other the armature current. Totally weird idea, but I wonder if you could learn to ride it. With independent controller control you could make a sepex motor have a super wide RPM range. Maybe.
Unfortunately that motor is a bit heavy. Like 60 lbs or so and a pancake PM motor weights about 20 lbs.
