Originally Posted by jeff88
So just tonight, I saw the wheels on an MR2.
One issue. They are 4 bolts. Is there an adapter I can use for my Corolla? Another concern is weight. I wonder if these would actually save me any weight at the corners.
I like these, because they offer some style, without being overly 'open'. The three holes also seem like they would make good mounting points should I want to make a cover of sorts.
Any ideas?
What makes you think they won't fit?
The info I can find shows that both the first gen MR2 and your '01 Corolla should be 4x100 lug pattern on the wheels. Corolla didn't get 5 lug until '03.
4x100 is a VERY common bolt pattern. Granted, you still have to think about offset and hub center diameter, but I'd bet you could find lots of choices if you poke around on craigslist.
This database can look up other 4x100 cars to source wheels from:
Wheel-Bolt-Pattern-Cross-Reference-Database
