Thanks for the help guys.
Originally Posted by HydroJim
check off set and wheel width before buying. very important factors.
I know those are important, but I'm not sure what I need. Do they need to be the exact same or is there play in the size difference?
Originally Posted by pacobeagle
What about Prius wheels, aren't the newer models 5-lug?
I think I need 4 lug wheels, so I will have to be careful, because the Prius has both, depending on year.
Originally Posted by ksa8907
We used to have an '87 oldsmobile cutlass siera, 4 cyl. Had steel wheels and completely smooth hub caps, 14" and 5 bolt iirc.
I may have to look into that for my GF's Cutlass Supreme!
I'd prefer alloy wheels, though for weight reduction. That seems to be my biggest problem. I can find wheels/hubcaps like that, but they are always steelies. I can't seem to find what I want in alloys.
Originally Posted by UltArc
Have you thought about making your own rim? AKA, pizza pans and painting a rim, or painting the "vacant space" of a rim?
I was thinking that exactly today. The only problem is that I still want to get alloy rims and if I'm going to spend the money on nice rims, I don't want to cover them up. If I can find light weight alloy rims that aren't necessarily nice (looks and aerodynamically), but super cheap, then I might go that route.
