in canada they claim 47mpg!
Two things about the Canadian / NRCAN ratings:
1) NRCAN MPG uses Imperial gallons (~20% larger than US gallons). So you can't compare NRCAN MPG to EPA MPG without converting.
2) NRCAN testing is still based on the old 2 cycle approach. The EPA has significantly changed its testing/reporting methodology since the days of the 2 cycle tests. So our two countries' ratings have not been aligned since pre-2008.
