Originally Posted by MPGsteward
Lowering not an option for me since i need to haul 1 ton of material. Pans attached with toggle bolts. It works, i used them on both my trucks.
If you need to haul 1 ton of material you have the wrong truck, your max payload is 1200 lbs and you will be riding axle on frame, i just about was with around 800lbs in the bed.
