I found that my timing isn't advancing enough and my static timing was at 7-8 BTDC. When I leanind it out a 1/4 turn and changed my static timing to 10 and raised my idle just a smidge it seemed to be better. I'm going to set it to 12 static and see if I can lean it a hair more. I think it was only advancing to about 35 total. Its off of ther measured scale. I'll have to find a way to scale it out to see. I did some measuring this weekend on the camper taper. Hopefully, I'll find some time to put the scaffolding together for the roof section at least.
