Old 10-30-2013, 09:44 AM   #4 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
I think that the conventional wisdom in the forum for this situation is that it need not fit the template, but should not exceed 22 degrees.
I've had positive results with Kammbacks & tails I've built that are "faster" than (fall "beneath") the template, but with the important distinction that I am always careful to avoid introducing sharp transitions.
(Though I'll also admit I haven't ever re-built a suboptimal mod to raise it up to the template line and compare the effectiveness of the two.)
I see a sharp transition here at the roof/Kammback transition, and also a sharp transition from the side of the Kammback to its top surface. That's where I see red flags.
"Think radius, not corner."
