Old 11-02-2013, 09:21 PM   #20 (permalink)
user removed
If you P&G (engine off) you are going from a significant impeller speed to basically nothing fairly quickly. While you jsut shut the engine off the turbine impeller could still be spinning at 20-30,000 RPM. Although you have shut off the heat source (combustion) you have not shut off the heat transfer.
Now you have a very hot turbo, with the shaft spinning rapidly and it is very hot, but you have eliminated the oil flow and coolant flow (if water cooled). Even with a high quality synthetic oil, you have a recipe for failure, a situation way outside design parameters.
regards
Mech
UltArc (11-02-2013)
