Old 11-03-2013, 05:16 PM   #2 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Welcome to the site! Looks like you are well on your way to a great vehicle.
Some suggestions:
*Maybe extend the front air dam down in front of the tires for a tire spat effect. This might make your air dam more worthwhile.
*I would seal up the outer edges of your belly pan, so that the coroplast attaches to the bottom edge of the side panel/door. I fear that air is coming in from the side, which might cause some turbulence and maybe a parachute effect, effectively making the pan useless. Seal it up and you might see a better result. (Only a thought, you'll have to confirm.)
*Kammback. You might be able to use the spoiler mounts to do it as well, so you won't have to make holes or even need tape.
*I would definitely try the rear diffuser. You can even design it so it deflects air away from your hitch, so that the hitch becomes almost non-exisent, aerodynamically speaking. You could also just extend the belly pan all the way out to the point of the hitch.
I have no advice for turbulator tape, but do a search here, I think there are a couple of threads that talk about it.
Don't be surprised if you have to replace your starter sooner rather than later. All that EOCing will kill your starter.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
