Originally Posted by krrcan
I have had 2.2 bars in all 4 tires, but last fill-up I upped that to 2.4.
Not at all sure what I should have, allthough the handbook recommends 2.1 front and 2 back.
Check the sides of the tyres, they'll most likely have the maximum pressure stated on them somewhere - usually in smaller letters.
I'm running 3 bar in an up, which is about the size and weight of your car.
BTW : VW recommend 2.2 bar for it
Depending on the condition of the suspension, you may need to back off a bit on the rear wheels if it becomes bouncy.
If the alignment was off by enough to cause uneven wear, it was likely off by enough to impact your fuel consumption.
Toe In - EcoModder
