Originally Posted by California98Civic
Notes: All seventh gen Civics had hydraulic clutches.
Trans case code SLW on sticker PLW on metal (Hybrid trans code SZB).
No one has successfully swapped a seventh gen (2001-2005) civic trans onto a fifth/sixth gen engine, or earlier trans onto seventh gen engine.
Wrong.
D17A2 in a '95 Civic using D16 tranny
There is very little reason to do this swap, so very few people do it. Shift linkages are very different (cables vs. rods), so you can't easily swap one to the other. But, if you try putting a D16 in a 7th gen Civic or a D17 in a 6th gen Civic, the engines and tranny will bolt up fine.
There's a lot of misinformation on this out there, so it's hard to find out the details. The link above includes pictures of the D17 with a D16 tranny.
