Originally Posted by rmay635703
Hmm, would you mind mailing  , I will have to see what is out there...
Anyway
I wouldn't mind seeing what the green diesel tune does, I would emulate that a tad, my main idea is to reduce EGR to stop the intake from plugging up every few years and improve the FE a bit by adding some timing.
Can you add EGR during warmup and turn it down once warm?
Shoot me an PM and we can get something worked out.
The VAGCOM can turn down/off the EGR but it can't do it based on temp.
Using the MPPS it is possible to do a dynamic EGR but that is only if the tables have been located for your version of the ECU. It is possible to locate the tables and make the modifications but I have not tried doing that yet since I do not want to spend much on the software.
