Thread: 12 volt Battery
Old 11-04-2013, 07:29 PM   #7 (permalink)
mort
EcoModding Lurcher
mort's Avatar
Originally Posted by RobertISaar View Post
if you want to make any noticable difference to the electrical system, expect to measure capacitance in F, not uF.
Adding a little to this thought...
Each farad can store about 100 joules at battery voltage (about 14.5 volts) 1 joule is 1 watt-second. So 1 F could store 100 watt-seconds. That's if you can convert the whole charge down to 0 volts. I guess you'd better assume you could use the top 30%, 14.5 volts down to 10 volts - you need 3 times as much capacity.
There is a hybrid cap called the Stinger available from car audio sources, it seems to be a combo capacitor & lithium battery which emulates 50 F. They cost about $200 each.
If you attached one of these in parallel with your battery, you'd gain 50 farad If you could use about a third of that (14.5 v down to 9.6 v) it would provide about 1,666 watt second. About 20 amps for 7 seconds to run your lights and radio.
-mort
The Following User Says Thank You to mort For This Useful Post:
TexasCotton (11-05-2013)
