Old 11-07-2013, 12:45 PM   #6 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by malko05 View Post
It seems unusual to have regular fluctuations (every 4 ~ 5 sec) on all values ​​at the same time. no ?
Loose electrical connections will cause all sorts of problems. You should solder your contacts (and also where you tapped your wires into your vehicle.
Also, what is a "normal"percentage of the CPU ?
With only the +12 v and ground connected, I'm 77%? Is this normal ?
I could not tell you whether it is normal or not, as I do not have access to meelis11's customizations. My own modifications consume anywhere between 6% to 38% of the available CPU, depending on what is being displayed.
