Originally Posted by BongoBennie
So on the engine note..... I looked around, is there any good threads about building an engine for eco? like thin titanium rods, knife edged crank, lightweight short skirt pistons? 13:1 like compression, turbocharging with economy in mind, I did see the lean burn tuning..... on that note, is there anything about the D15Z that makes it suitable for lean burn use, or is it all in the tune?
I'm still considering going back to a Honda platform running a modified D16Z6 engine with ultra lean burn capability.
The next one I would like to build would have around 14:1 compression with a turbocharger. It would run pump premium on the street with very low boost and a H2O/meth kit or I'm even considering a boost referenced propane enrichment kit.
Then for the track I would run e98 ethanol.
I'm still looking for a 1st generation Honda Insight that has a bad engine and battery to install this engine package into.
