Old 11-08-2013, 01:45 PM   #13 (permalink)
XYZ
Originally Posted by vskid3 View Post
I think you're confusing some terms. The sidewall max rating is the number on the tire, usually 44 or 51PSI for passenger tires. The manufacturer recommended pressure is on the door jamb and around 35PSI for cars and small SUVs. Inflating over the manufacturer recommended is generally considered to be safe, inflating past the sidewall max can be asking for trouble.
You are correct, and I stand corrected. I understand the difference but I got the two confused while replying.
Since the OP mentioned that he has them already inflated to the max sidewall pressure and since he is driving a truck, it would be good to heed the maximum load rating as well.
