Old 11-07-2013, 08:34 PM   #11 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
Originally Posted by XYZ View Post
You can inflate your tires considerably more than the sidewall rating. For example, if the sidewall rating is 28, you can easily inflate to 40 PSI. You can expect better FE from over-inflation, but also a much harder ride.
I think you're confusing some terms. The sidewall max rating is the number on the tire, usually 44 or 51PSI for passenger tires. The manufacturer recommended pressure is on the door jamb and around 35PSI for cars and small SUVs. Inflating over the manufacturer recommended is generally considered to be safe, inflating past the sidewall max can be asking for trouble.
Camry Thread
E-Bike Thread
Old 11-07-2013, 10:12 PM   #12 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by wmjinman View Post
The ScanGauge will help
The thing I liked most was the table I was able to create of mpg vs speed. ScanGauge testing allowed me to make a really good graph so I now know how much it helps to go at certain speeds. And that applies to going faster as well as slower. I know I get better mileage at 40 than 35 in the Jimmy, so if I'm on a road that's posted 35, I know that "cheating" and going 40 will actually have better mpg results.
This!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 11-08-2013, 12:45 PM   #13 (permalink)
XYZ
You are correct, and I stand corrected. I understand the difference but I got the two confused while replying.
Since the OP mentioned that he has them already inflated to the max sidewall pressure and since he is driving a truck, it would be good to heed the maximum load rating as well.
