Old 11-08-2013, 06:11 PM   #80 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Dmafanp, that's a good note about the weight. A perfect example is my vx swapped sedan that is 300 or so lbs heavier than a vx. The sedan coasts extremely well downhill with the extra weight and vx trans where on the same hill my vx sometimes needs a boost. Then again the vx takes less energy to accelerate with less weight so that balances out. My sedan also has power steering so that wil knock it down a little. On a perfectly straight road the lighter car will def outperform the heavier, but I certainly dont have perfectly straight roads around me.
Burn lean and prosper \\ //
