Thread: My 94 VX
Old 11-10-2013, 07:08 PM   #66 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
My car is typically bone stock or just slightly modded (upper grill block is needed when it is below 55*F because my engine does not make much heat at all, my thermostat may need inspecting again.) I'll eventually get around to adding an air dam and ducting the air path between the radiator and the intake and between the radiator and exhaust.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
