I could be wrong, but I'm pretty sure I read the bed side splits where the rust likes to start.
Anyway, i'm getting backwards progress
, now the truck don't want to start lol. Fuel delivery problem. If I put gas down the carb it fires right up and dies. Fuel pump is new, maybe fuel filter, or lack of a fuel filter? Carb seems to have some gas in it, pumping it does squirt gas out.
Yesterday I tried to tackle the other 2wd 1 ton driver's door, still can't get it opened. I sprayed it with some lube so hopefully over time it will unlock. I'm thinking it shouldn't be too hard to sneak a saw blade in and cut the loop the door latches on. Probably not keeping that cab anyway, but I do need to pull parts off it etc yet.
Hopefully I can report some progress soon, and get onto the ecomodding part of the truck lol.
