Old 11-11-2013, 10:15 PM   #108 (permalink)
Superfuelgero
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Originally Posted by slownugly View Post
Bongo- might be easier to play around with the head gasket thickness and shaving the head. Of course watching for valve clearance is part of the deal if its going to be really tight. Could play around with some pistons but I'm sure some flycutting would be in order. I was actually thinking about building a d13 and putting a z1 head onto it. Then some custom tuning would def have to be in order but I would think it would be awesome in a light crx. The z1 swaps in those already yield 60+mpg.
That's right, flycutting wouldn't be needed with a simple deck/mill. i've ran my D15z1 with upto 6 degrees cam advance without damage.
Some of these are on my list to try (along with the knife edging and coatings). I disregarded the D13 (or D12), since gas velocities would suffer while using the D15z1 top end. Going to an adjustable WAI would be better since it will have a similar effect by decreasing the air density, as well as wall heat transfer. My plan is a air to water IC, along with a ported vacuum heat riser (possibly over winter break).
If you guys like the spoiler setup, look into CCCRacing. I have one of their outlaw rear wings that goes all the way out to the bumper edge, and is a professionally made piece (but a little over the top looking).
Shooting for 600 miles of range at 65-70 mph out of a vx.
