Old 11-12-2013, 10:06 PM   #6246 (permalink)
jedsmd
PLUGnGO
jedsmd's Avatar
Originally Posted by mora View Post
I was not able to establish serial communication between computer and controller when fuse bits were not set correctly. Good indication about wrong fuses was slowly flashing led. Can't remember which one though. It flashed like one time per second. It should flash like 10 times a second. I think controller works like that but it is much slower as it doesn't utilize external oscillator.
No fuse bits are set, this is the first mention I have heard of setting fuse bits.
Is setting the fuse bits part of bootloading? I only bootloaded to flash memory so it would not have been able to set any fuse bits if was supposed to. Does anyone know how to set the fuse bits?
