Originally Posted by jedsmd
No fuse bits are set, this is the first mention I have heard of setting fuse bits.
Is setting the fuse bits part of bootloading? I only bootloaded to flash memory so it would not have been able to set any fuse bits if was supposed to. Does anyone know how to set the fuse bits?
The software you use to flash the atmega should have options for the fuse bits.
