Old 11-14-2013, 11:04 PM   #4 (permalink)
alohaspirit
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
No, you can not drive a Prius without the pack. You can have it refurbished for $1000-1500. There are a few places that will do it for you.
where would i go for this?
If you are handy, you can locate the degraded battery "sticks" and replace only those. Often times, balance charging can also restore some of the degraded pack performance.
Go to Priuschat.com and search for balance charging and stick replacement if you are up for doing the work yourself for a couple hundred bucks.
thanks. ill check it out
Past Present Future?
