Originally Posted by P-hack
here is a rally driver that spends a lot of time covering the brake once in the taller gears and uses his left foot a lot, even switches feet during braking at one point so he can get back on the gas sooner. Again, NOT economy style
If he pushes in the clutch, the whole pedal assembly (or at least the gas) goes down with it - why would that be
Or is it some tricky linking to keep the revs up on a race engine that may like to rev high, but also drops its rpm like a block of lead ?
