Old 11-16-2013, 03:20 PM   #111 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Mad Adder View Post
Is the Honda Civic VX the best platform to start with? ... Other than reading as much as I can, where should I get the best start?
For driving that has lots of steady-state freeway miles in the mix, a VX is a great platform. But a 1996-2000 HX is nearly as good, and if you swap in a 1992-1995 VX or CX transmission to the 1996-2000 HX (and it is a direct and simple bolt-on) you'll have about the same performance at a VX on the freeway. The advantages of the HX are that they are a little newer (lower miles), they are OBD2 (which is better for instrumentation), and have 14" wheels (for a few more high-FE tire choices).
Reading? ... always the 65+ mods list and the 100+ tips list at the top of the EM pages. After that... the coolest "mod" is an UltraGauge or a ScnGauge for your OBD2 port... because it helps adjust the nut behind the wheel best, which is where some of the biggest, quickest, free FE gains will be.
Welcome!
The Following 3 Users Say Thank You to California98Civic For This Useful Post:
eggroller (01-07-2014), MetroMPG (11-16-2013), pgfpro (11-16-2013)
