Old 11-16-2013, 03:18 PM   #31 (permalink)
VX.hatch
Update
Drove 100km today couldn't tell if gas needle moved or not. It still hesitated, only part throttle acceleration every gear but 1st, but it felt like lean burn misfire. I say this because 1st gear is the only gear without lean burn. Also I beat on it brought to it 160km during this drive. I did another partial compression check in 4 and 3 160 and 140. This was right after the drive. I also smelled the occasional burned oil smell after the beatings. Yes I did a couple 123 gear pulls. I figure if the motor wants to blow I'll blow it right now but it didn't blow so I'll continue with diagnosing with your help.
