Thread: Hi everyone
Old 11-17-2013, 04:39 PM   #7 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Looks like you picked up a pretty good base for a kamm/boat tail! Get the maintenance up to date and then start modding! The idle may be because of the cracked manifold. I wouldn't mess with the O2 sensor until after you fix the manifold, otherwise you might be wasting your time (and money).
Definitely air up the tires (40ish) and get an MPGuino.
Do a search on here for engine and tranny swaps. I don't know anything about the Civic line, but a lot of people are swapping between the different models. You might be able to swap a better engine and better trans and make a Franken-civic for the best results.
Also, I think you should put a spoiler on the back. Civic Spoiler
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
