Old 11-18-2013, 06:24 AM   #12 (permalink)
radioranger
radioranger
I would try to buy the newest model I could get ,the 98 and older maybe even 99 have an engine vibration issue and a smaller gearbox oil capacity which may not be a factor , I made a upper grille block out of sheet plastic/foam I got from a local plastic supplier , I will try to post a pic , had a bit of trouble figuring it out but it looks good and seemed to give one mpg,I run 42 psi front and 40 rear psi on yokohama tires and overly wide custom wheels that came with it , but it does handle well,
