Old 11-19-2013, 06:35 PM   #22 (permalink)
Recumpence
My C-Max - '13 Ford C-Max SEL
Here is an upper grille block I made today. I have about 45 minutes in it so far.
I have it mounted with a few screws for testing purposes. I will finish mounting it tomorrow.
I used a piece of 3/4 inch 6061 aluminum box tube bent to the shape of the nose of the hood as a support behind the grille to hold the proper shape since there is nothing at the top edge to mount the grille to. Otherwise it would try to flex flat.
The nose finally has that fully rounded look to it.
I will post FE numbers when I have them.
Matt
Name:	upper grille1.jpg
