Well I finally got through a full tank without the air foil on and the result was, well... meh. Tank MPG was 20.2, which is right at average. So at least for one tank, no measurably good results.
The average maximum temperature for the dates of this tank were 5° lower than the last tank dates. Would 5° effect my MPG so much that it would essentially nullify my mod?
10/30-11/9: 72°
11/10-11/20: 67°
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
