Old 11-22-2013, 10:37 AM   #28 (permalink)
justme1969
justme1969's Avatar
again It all sounds great but.
Originally Posted by Idratherbeflying View Post
Yes less weight is always better. But i also have a small budget for this project if i do it and light diesels are a bit pricier but im definately looking around for light ones. Another thought i had is to drop a gm 6.2 diesel into a pontiac firebird. My dad has one that had a fire under the hood ( there has to be ha good joke there somewhere ) i could get cheap and the 6.2 can be had cheap.
Max Power @3000 RPM hp (kW) 1 22.1 (16.5)
Displacement cu in (cc) 76.2 (1248)
Bore in (mm) 3.7 (95)
Stroke in (mm) 3.5 (88)
Max Torque lbs. ft (Nm)1 38.7 (52.5)
Look at the lack of torque it just isnt there. Ive also wanted to do this for awhile with my 03 civic. but what I sent before, that isnt just an off handed comment. I witnessed a mini china truck attempt an on ramp and ditched out at last second and slide down the hill trying to merge. This is a on ramp I always took for granted but always tried to merge into at about 70.
He had found 45 maybe and it wasnt pretty.
