I registered here at Ecomodder just so I could get in on this thread!
I'm in the process of building my wiring harness right now. I'm about 75% finished and there's a part of the OP that I'm reading that I need clarification on....
You create your custom harness by wiring them together as follows:
8-pin female.
pin 1 needs to be wired to 4-pin male, pin 4.
pin 2 needs to be wired to ground, G101.
pin 3 needs to be wired to 4-pin male, pin 2.
pin 4 needs to be wired to 6-pin male, pin 3.
pin 5 is not used.
pin 6 needs to be wired to 6-pin male, pin 2.
pin 7 needs to be wired to 6-pin male, pin 6.
pin 8 needs to be wired to 6-pin male, pin 5.
The wires from 4, 6, 7, and 8 need to be shielded, and the shield should be grounded.
Specifically, I'm looking at the last line where it says 4, 6, 7, and 8 need to be sheilded? what exactly does that mean? I'm putting the ground wire on the 8pin Female, pin 2. Do I need to do anything more to "shield" it?
