Old 11-24-2013, 11:26 AM   #18 (permalink)
Superfuelgero
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Most of the weight is in the belts (25-30lbs). The tops are 21lbs, the bottom is 8lbs. So in total you should be able to cut about 60lbs. I have kids, so I can't do this.
The rear side window in lexan are pointless to do. You save a whopping 1.5lbs per side.
There are too many threads online to count on the subject. I will suggest: the insight brakes, 1 piece front end, a smaller battery, lighter flywheel, and removal of the washer system(s). I wouldn't recommend: gutting the isolation (sound is horrible on the highway), removing carpet (same), or JDM lenses (yellow over time).
Shooting for 600 miles of range at 65-70 mph out of a vx.
