Old 11-24-2013, 12:21 PM   #4 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Although I usually suggest the Escape Hybrid like xntrx in threads like these, I would think that vehicle might be a bad idea. The reason why is because it only has a load capacity of like a 1000 pounds. It's not driving forward that's the issue, it's driving backwards. In reverse the hybrid only uses the battery/motor, so it can't have heavy loads in reverse, something you need to do to get the boat in the water. The other reason is because the batteries are just under the rear cargo area. If you accidentally get water in there...
Other than that, I think the Escape would be a great idea. How much elevation change?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
