Old 11-24-2013, 02:33 PM   #11 (permalink)
Superfuelgero
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Mine said it was the same, it was underdrive. had to go with 1-2 inch shorter belts.
The flywheel helps bump starting slightly, engine braking is increased slightly (more in tune with other drivers though), idle is the same. Shifting is a huge difference though. I clutch-less shift, so the wait between gears is a lot less. This is where the gain is, less time out of gear. I wouldn't recommend it without a short shifter, even then you have to be faster. It does take some getting used to, I stalled it more times than I care to think about the first week. If you drive in town, its a plus, highway mainly, not so much.
Shooting for 600 miles of range at 65-70 mph out of a vx.
