Old 11-26-2013, 12:18 AM   #22 (permalink)
vlad
Originally Posted by P-hack View Post
I don't understand what the hangup is. You compress the gas, then you regulate it going into the engine, regardless of the psi. What are you looking for?
It doesn't matter what pressure you have in your tank. You have pressure regulator to take care of this....
The point is to put as much gas as possible into your tank (in safe limit of your tank)
The pressure of CNG going to engine will be low
