Old 11-28-2013, 02:42 PM   #7 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Check the manual, and you may find a second, higher set of pressures specified for traveling at sustained high speed (or with a full load). That will give you an idea of what range the manufacturer considers reasonable.
Nobody can really give you a specific answer for your question, because it depends on your road conditions & driving style.
But most people will agree that the manufacturer suggests pressures that are a compromise of comfort/handling/economy. Many people here just add a bit of pressure, little by little, to get a sense of how it changes the equation.
