Old 11-29-2013, 06:44 AM   #158 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
I put the voltage regulator where the old warning flasher went. My new wiring harness has the flasher in the fuse block. I adjusted the regulator to 5v and tested it with 12v and 14v supply. Both were right on the money. I even used the new fuel sending unit to test it. Yay
Burn lean and prosper \\ //
