Thread: New Member
Old 12-04-2013, 01:13 AM   #22 (permalink)
cRiPpLe_rOoStEr
Just regrinding the cams and increasing the static compression ratio wouldn't make it operate in the Miller cycle, would only make it operate like a Prius engine, emulating the Atkinson effect. The supercharger is also required for the Miller cycle in order to overcome the discompression provided for the longer intake valve timing.
Originally Posted by TruckFan View Post
I've read some about the Miller cycle, but what really makes it more efficient? If you have to use a supercharger to get the same power out of the same engine then it seems that it would be less efficient per cubic inch or cc.
Since the engine operating in the Miller cycle would still have less of the so-called "pumping losses", because its effect makes the power stroke longer than the compression stroke, the engine is, in fact, more efficient.
