Old 12-04-2013, 07:51 PM   #33 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Well I had a minor set back this week. On the way to school, about a mile up the road from home, I heard a nasty sound. I thought it was my timing belt, but the truck was driveable. It turns out I was close as my UltraGauge had a P0305 code: misfire on cylinder 5 (my UG is in my Corolla, so I couldn't check until I got home). Generally you would think with new spark plugs the culprit would be the ignition coil and/or wire. Well when I took the coil off, I decided to pull the plug, just in case. I'm glad I did! The node (or center electrode) completely broke off! Now I'm nervous about replacing the plug. Where is that node? I don't want to cause further damage to the cylinder/piston.
Here's the broken plug:
Anyway, non-aerodynamic issues, but aerodynamics obviously don't matter if the truck isn't going anywhere.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
