As far as I know, the truck is not running any sort of lean burn outside of factory specs. I haven't done any mods to this yet. The plugs are supposed to be OEM replacement. I didn't get anything fancy and I didn't get the cheapest ones I could find.
I just happened to be with my friend (and mechanic) tonight, so obviously I talked to him. He said it is probably just a defective plug and the piece that broke off will be burnt up and long gone by now.
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
