Old 12-06-2013, 10:19 AM   #178 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by Miller88 View Post
tried to make it aerodynamic ...
I don't like the car's styling either. But they did succeed in making it aero: Cd 0.28 is what we get in North America. That's best in class.
Also, there is partial underbody aero paneling. See:
Aerodynamics of the new Mirage (.27-.31 drag coefficient varies with options)
Seconds - I do NOT trust Mitsubishi products.
10 year/100k powertrain warranty, which obviously includes the CVT. They can't afford to be doing warranty work on a $12k car. This particular CVT has been in production since 2009 (used by a number of manufacturers), so it's probably safe to say they've worked the bugs out. And 74 lb-ft of torque isn't going to stress it.
- EPA mileage rating is way off.
Lots of reviewers have found the same thing -- the car is meeting/beating its ratings when driven "normally", even with some aggressive driving thrown in (as reviewers tend to do). For some reason, Mitsu was a little conservative with this car's MPG ratings. On top of that, the onboard MPG display not overly optimistic (some owners are reporting it's actually slightly pessimistic).
I was able to beat the EPA rating in city driving with minimal effort with both the CVT and manual transmission:
http://ecomodder.com/forum/showthrea...age-27384.html
how will this engine be at 50,000 miles when the external balancing wears out
External balancing?
- Grille block could easily be added (1.3L getting > 50MPG probably will not make much heat)
It's actually 1.2L.
And agreed - more blocking is doable. (It's been done on this Florida Mirage already: http://mirageforum.com/forum/showthr...-(Garage-entry)
