Old 12-07-2013, 09:08 AM   #2 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Is it a manual transmission? If so, I have nearly the same car, or had nearly the same car before mods. The usual simple stuff true for most cars will help you: pump up the tires. Mine are at 55-60 psi most of the time. Get a ScanGuage or UltraGauge (it will pay for itself through improved fuel economy) and then learn to drive at 75% - 80% load, shifting at 2000 rpm, give or take 100. An air dam and grill blocks are easy and cheap to make and have helped me a lot. My best engine mods were to get rid of power steering. It was only an option on this lightweight car. You don't really need it. I have done many other mods, all detailed on my car's page, often with links, meant to help new people as well as just document my process a little.
WELCOME!
Start a fuel log so you can track progress over time.
MetroMPG (12-07-2013)
