Old 12-08-2013, 03:46 PM   #186 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
The Up is even shorter than the Mirage, I think.
The up! is 17cm / almost 7" shorter than the Mirage.
Mirage gets a 0.27 rating in Japan and UK. But they also have a 1.0L engine option, and the size of the grille openings (fixed) on the Mirage vary depending on drivetrain combinations, with the biggest opening for the 1.2 CVT.
Grille should be easy to fix
Wider wheels would also make a difference.
