Hi!
I figured I post a few pics here since I did some things to the mirage.
-As seen on my avatar I made a set of smooth wheel covers,if there is interest perhaps I could post in the DIY section on how I made them.
- Tinted the windows.It's almost necessary in FL
- Made a better looking lower grill block (better than foam strips stuck in the gaps)
- Lowered the front about an inch,maybe less,using spring clamps for now.
-The side of the car was "missing" something so I applied a sort of stripe that I got at an auto parts store as two 6'X6" rolls.
- I also did LED conversion where it was possible. (tail lamps not possible.While I got them to work properly,I ended up with ABS and traction lights with brake lamp circuit fault codes in the system)
So LEDs are front side markers,frt.parking lamps,tag lights,trunk light,dome lamp.
Here are some pics:
![](http://ecomodder.com/forum/member-3dplane-albums-2014+mitsubishi+mirage-picture5757-131208-0007.jpg)
Grill block:
![](http://ecomodder.com/forum/member-3dplane-albums-2014+mitsubishi+mirage-picture5756-131208-0006.jpg)
Wheel cover close up (before lowering):
Thanks for looking!
