Old 12-12-2013, 02:02 PM   #26 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by JasonG View Post
Your wife's 2011 is much larger than your MKIV.
Actually they are pretty similar. The A3 is the baby Audi here in the States. I took a tape measure to them both in the garage the other night and they are essentially the same width. The Audi is 2" lower roof height so less frontal area. The Audi is slightly longer but has better plan taper than the Golf.
I believe the biggest difference is the particulate filter/regeneration and increased use of EGR on the Audi affecting the mileage.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
